So my alternator belt had broken. I went to Advance Auto picked up a new one. Got it home did what I had to do only to find out it was to big. I looked up part numbers on the web and went back to the store and double check part numbers. Everything is pointing to this belt I have as the right one. Anyone ever have this problem or and advice?
Alt. Belt to big.
I got a belt from there also and it was too wide for the pulley (like you I double checked the numbers and had the right belt as supplied by Advance but it just wasn't the right size). I ended up getting Bando belts from "smallcarparts.com" which is local to my area. Let me know if you need the Bando number. I believe Bando was/is the OEM supplier.
do you still have the old belt? match up a new one to it and you'll be good. They shouldn't stretch that much.
member's ride thread
91 Accord SE 176k
autozone, advanced, napa they all suck, ive ordered numerous num matchin belts for a slew of diff cars, when u get tired of argueing with them have them measure the belt and give you one according to the length and belt pattern you need.
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Thats what i meant take your belt that is too long measure it and get a shorter one the stores have a devise to properly measure the belts
