Alt. Belt to big.
    Alt. Belt to big.
    So my alternator belt had broken. I went to Advance Auto picked up a new one. Got it home did what I had to do only to find out it was to big. I looked up part numbers on the web and went back to the store and double check part numbers. Everything is pointing to this belt I have as the right one. Anyone ever have this problem or and advice?
    Click For Full Details->http://www.cb7tuner.com/vbb/showthread.php?t=177213
    Chozen Few Customz _CT_
    Does your car have a/c? and can you adjust the alternator to tighten the belt at all?
      Yea I do have a/c and the alternator is pulled as far out as it can be, its adjusted to the max and still the belt it 2-3in too big
        I got a belt from there also and it was too wide for the pulley (like you I double checked the numbers and had the right belt as supplied by Advance but it just wasn't the right size). I ended up getting Bando belts from "smallcarparts.com" which is local to my area. Let me know if you need the Bando number. I believe Bando was/is the OEM supplier.
          do you still have the old belt? match up a new one to it and you'll be good. They shouldn't stretch that much.
            I too had a issue with 2 belt's that Advance had sold me before on a 2000 civic. Both were the incorrect size. I checked there website and the guy sold me the incorrect belt and I told him the car had A/C. I would rather go to AutoZone. Also, Advance's website is a little odd.
            MRT: http://www.cd5tuner.com/vbb/showthread.php?t=5748
              Ditto
                autozone, advanced, napa they all suck, ive ordered numerous num matchin belts for a slew of diff cars, when u get tired of argueing with them have them measure the belt and give you one according to the length and belt pattern you need.
                http://www.cb7tuner.com/vbb/showthread.php?t=187851
                sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
                bought from:jokerxfn-tommi-'93cb7ex
                  The old belt was shreaded and twisted to shit so I cant match it up I tried. Im goin there now to see if they can just give me one with the same # of ribs jus 2-3in. shorter.
                    Thats what i meant take your belt that is too long measure it and get a shorter one the stores have a devise to properly measure the belts
