Spark,Compression,and Feul ...still not starting...??
    okay. so i did the jdm f22b swap in the 92ex...and its trying to turn over...just isnt..i checked all the grounds i could possibly think of and its getting the comp. gas. and spark...its started before...but the next day it wouldnt...and all i would do is close the hood and go @ it the next day...so just wondering if there was anything major that i could be missing. suttin that alotta people forget that im overlooking...idk. any info would be helpfull. thank you!
    timing
      Have you messed with the distributor any? Sometimes I get a little retarded and install the dizzy shaft on the cam wrong resulting in the timing to be off 180*. If it cranks up it wont run right.
        the timing should be all fine...nuttin got changed with that and the car starts sometimes. but ima check that one more time today. ill let you guys knoo. and the i never touched the dizzy...so that should be str8...cause the car was working fine in my boys car like 2 months ago...so lemme check timing
