car cranks but doesnt turn over
    i had another thread in the begginer tech thread but i wnated to ask here
    my car cranks but doesnt turn over
    its a 92 cb ex with f22a1
    all parts im gettin are free btw so people please dont go crazy saying test stuff before u go spending money ok ok
    ok so i changed the igniter and tested it its fine
    i changed igniter cap rotor and it still doesnt get spark
    all the fuses are fine i tested them all
    the timing belt isnt popped
    im runnin out of most logical problems
    is there something else that can cause this?
    Main relay, bad fuel pump, fried ecu, blown fuses, and bad distributor.
      thank you shag
        with any luck, it's just the main relay. try this:
        http://www.cb7tuner.com/vbb/showthre...ght=main+relay
        if it's no that, you probably have some worn distributor components such as a bad coil or ignitor.
        you should check for the basic things that make a motor run ie; spark, fuel, air, and compression. later.
        Avoiding dirt at all costs
          its gettin fuel air and compression is good
          its not gettin spark i changed the coil, igniter cap, rotor and cables all for free of course
          the main relay seems to be fine
