i'm throwing a code for the egr cuz i disconnected it. understandable. but every time i start up the car, no code appears. it doesnt show up until the car warms up. i'm assuming its just not storing codes for some reason, and every time i start it, it acts like a new ecu learning howto drive the car most efficiently. my other ecu does the same. any ideas why?
ecu not storing codes
2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride ThreadTags: None
Originally posted by HondaFan81 View PostIf your observations and/or assumptions are true, then something is up with your electrical system causing a low/no power issue.
Does your clock also reset and you have to adjust it as well? If so, that confirms the above.
i was hoping there was a certain fuse or wire that i could check. i'll double check the ecu this weekend2013 Ice Cream Cruise!
By 1320 Video
ok, so took a while but i tried throwing my other ecu in and the same thing happens. not storing codes. all other electrical items are working fine. i don't think its plausible that i have two bad ecus. is there a certain wire to the ecu i can double check?2013 Ice Cream Cruise!
By 1320 Video
Originally posted by theSOB View Posti'm throwing a code for the egr cuz i disconnected it. understandable. but every time i start up the car, no code appears. it doesnt show up until the car warms up. i'm assuming its just not storing codes for some reason, and every time i start it, it acts like a new ecu learning howto drive the car most efficiently. my other ecu does the same. any ideas why?
Also I thought the Egr doesn't require a signal until the engine is up to operating temp
My 5.7 LS1 Holden Ute
Originally posted by evil_demon_01 View PostWhen you say its not "storing codes" Do you mean that when you jump the short connector no codes flash?
what happens is every time i start my car, no codes show. i have to wait for it to reach running temp til the cel comes on. thats not normal2013 Ice Cream Cruise!
By 1320 Video
I agree if you are using OBD-I ECUs that the code should be stored from one trip to the next.
I am curious, did you disconnect the EGR Lift Sensor (on top of the EGR Valve) or EGR Solenoid (inside the black box that has all the vac lines going to it)? If you disconnect the EGR Lift Sensor, I would think the ECU would see the input missing from start-up. If you disconnected the EGR Solenoid, then I imagine the ECU would not realize something is wrong until it is unable to control the EGR after the engine warms up.
As far as the engine running like it has to re-learn everything, try running the car with the blue connector jumped. I thought this keeps the ECU in Open Loop; no trip data collection, no HO2S input.
If you suspect a power loss at the ECU, unplug it and probe the memory wire. You should see voltage with the car off, and there should be zero ohms resistance between it and the memory fuse (a good way of making sure you've got the right wire).1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Originally posted by James Matteu View PostI agree if you are using OBD-I ECUs that the code should be stored from one trip to the next.
so there is a memory wire? and fuse? where are those located, do you know? i suspect its something like that as i've tried two different ecus with same results2013 Ice Cream Cruise!
By 1320 Video
Memory fuse is a 7.5A fuse in the Under-Hood Fuse/Relay box, the memory wire is a small gauge Red/White wire; you will need to consul a pin-out for your ECU to determine its exact location.1997 Honda Accord EX-V6:
