I noticed the day before yesterday that the D4 isn't lit up anymore. All of the others are working. Any ideas? I am talking about the indicators in the cluster.
D4 not lighting up?
Bulb is probably burnt out. When I got mt SE, it had the same problem. I took out the cluster and swapped the D1 bulb with the D4 bulb and it has worked ever since (over 3 years so far)Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
Originally posted by 4GAccordH22 View PostBulb is probably burnt out. When I got mt SE, it had the same problem. I took out the cluster and swapped the D1 bulb with the D4 bulb and it has worked ever since (over 3 years so far)
Originally posted by Shag Wagon View PostOr either the TCU is about to die......
she is down....but definately not out
you have to unscrew them from the circuit board but if you leave the front window on, the gauges will remain in place. This way all you have to do is remove the circuit board from the back of the cluster.
Watch out for the odometer cable though. it will stay with the cluster and is connected to the circuit board.
