A/C Clutch Relay location
    Okay so my A/C was working before i moved out here to Colorado. In California it blew cold ass air, but since i moved here it has not worked properly. I turn on the A/C but the clutch doesn't activate! everything turns on but i can figure out where the A/C clutch relay is at! Help!
    TIA
    Rip It Up
    Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
    Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
    i vouch for my Brothas
    bump. searched but could not find anything, so don give that bs
    Rip It Up
      Rip It Up
        bump!
        Rip It Up
          I haven't had the need to find mine, but this is from another site:
          in engine comp. left fender next, behind p/s fluid reservoir. there are 2 relays 1 is for the condensor 1 for the a/c clutch.. the 1 with a red wire is for the a/c
          Sig removed due to excessive size.
            I recently answered this in a different post. There's also a picture.
            http://www.cb7tuner.com/vbb/showthread.php?t=163369
              do you have enough freon in the system? I know CO has a much higher elevation than CA so that could be affecting it also.
