I Made a thread a while back about how my car wont rev past 4000.
Now i have swapped in a jdm f22b with a 14b setup and still i have the same problem. I have changed the spark plugs, ecu, fuel pump, injectors, main relay, distributor cap and rotor, oem map sensor, and o2 sensor I have no idea what could cause this.
I do have a cel that i cant seem to make flash when my p06 is installed but when my original ecu is installed it flashes the code for o2 sensor heater. Its becoming really frustrating. any help would be great. Thanks
