Brake Light On
    Brake Light On
    So...i've encountered a new different issue...My Brake light stays on...Why won't it go away!?
    -There's no hold back, meaning it doesn't feel like my brakes are still on.
    -It drives fine
    -Brakes fine
    -Ebrake work as normal
    This actually has been on for a little more than a month. Never got to it. LMK what it is!
    *Needs*
    -New shocks
    -Struts
    -Drop
    -Cleaning
    -New Tires/Wheels
    -New Window Tint
    -Alot more lovin'
    Fluid Level?
      your fluid is gone
        break light in dash or break light in the rear..? check the break light switch right above the break pedal..
          This is your problem, I'm almost 100% sure of it. there is a little piece of plastic onthe brake pedal that pushes on the brake light switch to turn the brake lights on & off. yours is probably gone & needs to be replaced. so look at the leg of the brake pedal under the dash & u'll c the switch, it's long & cylindrical feel up n there & c if u feel the piece or just a hole & u'll know what u need to do.
          http://www.cardomain.com/ride/3222203/5
