well i got a h22 tranny the problem is that that trans mount broke so the trans is hanging not even held but i also see that the trans cables look loose. the shifter is in nuetral but the trans is stuck in third gear how can i fix this plz help
help
1) Make your thread titles descriptive. This site is intended to be a searchable database of information, not your personal helpdesk.
2) Fix the transmission mount. If you still can't get the transmission to go into neutral, then there's a problem. But we can't help you until you fix the one glaring problem.
How the hell did the mount break, anyway?
Originally posted by deevergote View Post1) Make your thread titles descriptive. This site is intended to be a searchable database of information, not your personal helpdesk.
Well what you will need to do is drill that nut out on the mount and run you another bolt and nut on there. The best way would be to figure out how to bust apart the nut from the mount. Hang your tranny and then see if she shifts. I know that when the 5 speed swap mount (welded to the frame) broke it made a shit pot of noise and the shifts were wierd. Fix other things you know that are wrong before you freak out and make a thread.
