New alternator, new battery, both tested out good. When I first got the car, I was told the alternator was bad. Well I put a new battery in, and drove it for 5 months with no problems. Then it stopped charging. Put a different used alternator in it, and it worked fine for another couple of months. Then it stopped charging again.
So, after putting new alternator in, and new battery, it still wouldn't charge. The alternator just wasn't putting out any power. So, after checking out the ECU, I noticed the vtec pressure switch and vtec solenoid were NOT plugged into the ECU. So, after hooking those up, I tested the alternator with the volt meter, and it WORKED!! The alternator was putting out 14v and the battery was getting 14v.
2 days later, went out to start the car, battery was dead. Jumped it, tested alternator with volt meter, 12.4 volts Any ideas? What would the vtec pressure and solenoid have to do with the alternator? Is there any other wiring I should check? The alternator IS recieving 12v from the ignition power source.
