Is my alignment out of spec?
    Hey there,
    This is a completely stock 90 EX daily drive.
    Firestone did an alignment on it and the passenger rear tire's camber is now -1.3 degrees. It wasn't adjusted at all and the print out says -1 to 0.0 is the specified range.
    The toe was adjusted from 0.22 degrees to 0.04 (with a specified range of 0.0 to 0.16) so I'm wondering if it was so out of wack that the camber couldn't be adjusted also.
    Any ideas on this? Is it a problem? Something they should fix?
    The service manager said it was good to go and I didn't notice the "out of spec" till I got home.
    90 Accord Ex, F22A4. Slight fire damage.
    why should they fix a problem that was already existing?
      What?
      Why wouldn't they align the components so they were back in spec? That's the purpose of getting an alignment.
      Am I not understanding your question?
        because camber is non adjustable from the factory... search next time or open your eyes.
          If you have a camber problem at the stock height then you have a bent part.
            Tippy, thanks for your help. That answers my question.
            I'll look around and see if I can figure out what the problem is. Any clues what I should inspect first?
            Wed3k, no need to reply if your answer isn't going to address the issue. You did, however, take advantage of the opportunity to sound like an ass. Good work on that.
