Dont be surprised that the outlets from the iacv and the other valve there (forgot what its called rite now) fall rite off when you take the hoses off. Strong chance that they will b reak right off from the corrosion. I would have back up valves just in case. Also check your coolant, it might be a rusty color by not. You should flush your current coolant with the blue stuff from honda.
Ok, So WTF Caused This ???
Originally posted by CBAccordA4 View PostDont be surprised that the outlets from the iacv and the other valve there (forgot what its called rite now) fall rite off when you take the hoses off. Strong chance that they will b reak right off from the corrosion. I would have back up valves just in case. Also check your coolant, it might be a rusty color by not. You should flush your current coolant with the blue stuff from honda.
And yes, CBA .. I have thought about what you mentioned ..
I should find another one at the yard before I even attempt this ..
Thanks guys .. I'll keep ya updated!
Update:
Called All-Jap Junkyard and they has an IACV waiting for me upon arriving.
Immedietly called Mike and Kyle at CNC Racing (right around the corner) and had it installed with new hoses .. turns out the coolant was fine .. sensors and everything else were a-ok.
Total cost was about $90 and I can't believe we didn'nt even have to adjust the new IACV .. just topped off the coolant and I was good to go ..
Aarron did mention that my blinker fluid was low tho .. I said no biggie ..
I never use um anywayz ..
Thanks for all the help fellas .. hope this works out in the Vegas heated desert!
You know...I didn't know your blinker fluid was low...maybe that caused the leak and corrosion.
Glad we could fix that for you. Did Aaron give you the old one? If so, you should post a pic of the broken nipple.
-KyleSOHC Non-VTEC F-series for life
"It is the fools prerogative to utter truths that no one else will speak."
-Morpheus (The Sandman)
ahahaha .. LMAO Kyle ..
And no, I didn't get the old one back, unless Aarron threw it in the trunk .. ?
I'll check laterz .. and hey, thanks for gettin me in on such short notice ...
I asked Mike to put me on the list for one a the new tee shirts ..
If he comes out with a decal .. I might be interested in that also!
Once again .. thanks for the help mates!
CNC rawks!
