What did the B18 engine originally come in. I recently read an article that had a turbo charged B18 that had over 450hp. I was just wondering what car they came in
B18 engine
Originally posted by fizzbob7
b18a1 was 90-93 integra gs but the 92-93 gsr used a b17a1 that was similar to the b16a in the civics.....then in 94+ the engines were either the b18b1, or the b18c1 (gsr) and b18c5 (type r)........the b18a1 and b18b1 were basically the same but used different on board diagnostic systems......it's easy to build the b18a/b up to be turbo monsters........with a stock bottom end they can make over 300hp.....my friend has a b18b with a 10psi t3/4 setup that runs high 12's in a civic without traction through 1st and 2nd gear......nice, fairly inexpensive setups
b18a - 130 hp
b18b - 140 hp
ppiDD: 1998 Honda Civic EX Coupe
PC: *searching*
the info i have says the 92-93 b18a1 makes 140hp while the older b18a1 only makes 130....the b18b1 should make 142hp though....all have 9.2:1 CR though according to what i got
PC: *searching*
