crankshaft pully..
    crankshaft pully..
    is it the same on the h22a an f22..I wana remove the lightweight pully, im tired of the idle problem, i have a h22 pully(small chip) and a f22 pully but are they the same?
    http://cb7tuner.com/vbb/showthread.php?t=85320
    I have a spare H crank pulley I can measure if someone has a F they can measure. But I believe they are the same.
      they are not the same. h22 has 5 ribs f22 has 4 ribs so the h22 one is wider than the f22 and will hit the frame rail.
        interesting.. thanks
            It will bolt right up but they are different in sizes and ribs like he said.
            I've been through both light weight (for F22 and H22) and stock because I thought they pullies were woobling, but even the stock one does at idle. Mine has also came loose recently, pretty messed up...
            H22a they always smile before Vtec....
            VIDEO WATCH ME!!!!
            My Members Ride Check It Out
              why would you have an idle issue with a lightweight pulley?
              I <3 G60.
                it won't hit the frame rail. My H22 has the H pulley and it clears.
                You'll need the H pulley if you want PS w/ your H22. Otherwise you'll be shredding belts because its offset by 1 rib, thereby making the belt sit at a weird angle in relation the the PS pulley.
                member's ride thread
                91 Accord SE 176k
