dsm injectors
    dsm injectors
    Has anyone used the blacktop dsm injectors from a second gen? And if it works will I run into any surprises? Thanks.
    i used em on my f22 dsm turbo setup. No different then using the blue tops. Same thing except BETTER spray pattern.
      I know from personal experience, black top injectors will connect into our 90-93 OBD-I vehicle harness connectors. They are peak & hold like stock, so no issues there. Keep your injector resistor module installed.
      Now, if memory serves me right it will be a tight fit on the IM bore side. Might have to play around with getting injectors to sit stock-like position.
        Thanks guys. I'm getting the black tops for 40 bucks that's why. I guess bisi said to get bigger injectors an a fuel pump just in case.
          im running DSM blue tops tight fit but installs fine
            so the blue tops are direct fit to our cars?
            Turbo F22 Under Construction
              Yes
              My 5.7 LS1 Holden Ute
