Ok i have a 92 accord and when i come to a complete stop my rpms drop all the way down to 200-400 rpms and i get a very bad vibration and its starting to annoy the hell out of me i know that the normal idle speed is 800 rpms so i was wondering wether any one could tell me how i could get my rpms back to normal i would greatly appreciate thanx.
very very low idle speed
dont adjust ur throttle cable, adjust the throttle body screw almost under that red vacumn line first...that will raise or lower the idle then reset the ecu.
set that to about 700-800 rpm.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztechdont adjust ur throttle cable, adjust the throttle body screw almost under that red vacumn line first...that will raise or lower the idle then reset the ecu.
Originally posted by HACORDquestion how do i go about reseting my ecu i know that might sound dumb but never dune it before thanx for the info
I too would say just adjust the screw on the throttle body to fix the idle speed.2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
Okay....TO RESET BASE IDLE: Warm car up to normal operating temp, unplug the IAC motor, then turn the idle screw counterclockwise to increase idle speed. Next, plug IAC back in, THEN shut off engine and pull the ECM fuse in the underhood fuse box for 10 seconds.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Originally posted by mrhondaOkay....TO RESET BASE IDLE: Warm car up to normal operating temp, unplug the IAC motor, then turn the idle screw counterclockwise to increase idle speed. Next, plug IAC back in, THEN shut off engine and pull the ECM fuse in the underhood fuse box for 10 seconds.
sorry to sound like a noob. haha. But i didn't know much about the idle screw when i went to adjust my idle so i adjusted my throttle cable. Is there a certain "spec" the cable should be at? I know that adjusting the throttle cable does affect engine rpm, but does that affect pedal feel? Is it okay that i adjusted the throttle cable and not the idle screw?
Originally posted by cokinutsorry to sound like a noob. haha. But i didn't know much about the idle screw when i went to adjust my idle so i adjusted my throttle cable. Is there a certain "spec" the cable should be at? I know that adjusting the throttle cable does affect engine rpm, but does that affect pedal feel? Is it okay that i adjusted the throttle cable and not the idle screw?
