So i had no luck at all in the past 2 months in my swap.
F22a6 auto to a P0F H22a auto
I get a map sensor CEL.
Map sensor on TB not hooked up to MAP in car, instead i plugged up all the vacuum lines, except line 24, into the throttle body. When 24 is plugged up, the idle drops and the car shuts off.
Left 24 unplugged and dotn get anymore CEL for map sensor.
I drive the car, CEL at 7,500 rpms, or 30-35mph for knock sensor.
Had the knok and oil pressure sensor swapped, fixed the knock CEL.
Got everything running with no CEL.
But now, the car BOGS. Only on light throttle, the car would go without feeling like there isnt enough fuel being fed, or where i would get pre ignition.
Could it be a bad EGR?
I tried to take off the EGR with no luck as i dont have a crooked 12 to get to the nuts.
Is there any other way i can clean it?
Is the EGR my main issue now? Or fuel filter? I never replaced the fuel filter.
