Did a wire tuck on the driverside. Accidentally clipped some wires when cutting the hole. Missed a plug had to extend didn't realize I still had key in ignition and aux power on cut two wires then when I went to go for a drive and I noticed that my clock wasn't working tach wasn't working speedo and Coolant gauge too. Also windows won't roll down I am clueless. I checked fuses they are all good.
Did a wire tuck no power to certain components
~Nick~
Tags: None
Originally posted by bluecb7 View PostWhat wires did you cut? Have you checked to see if you are getting power to each of the components? Were they working before the wire tuck?
Just wanted to know if anyone knew what all 4 things had in common such as a fuse or a certain wire.~Nick~
sounds like you cut either a common ground or common power to the gauge cluster. The key being on shouldnt make a difference and to me is irrelevent of your situation.
The launch control is what throws me off unless you somehow cut the clutch switch wires.
also if your tach isnt working then how do you know you cant go over 3500rpm?
member ride thread
DIVULGE MOTORSPORTS
Originally posted by turbo90accord View Postsounds like you cut either a common ground or common power to the gauge cluster. The key being on shouldnt make a difference and to me is irrelevent of your situation.
also if your tach isnt working then how do you know you cant go over 3500rpm?~Nick~
Originally posted by Grumpys93 View PostBecause my full throttle launch is set at 3500rpm and when I go for a drive when I get to those rpms it goes into full throttle launch and the rpms just bounce can't go past it.
member ride thread
DIVULGE MOTORSPORTS
Originally posted by turbo90accord View Postit is physically impossible for your engine to "go into full throttle" because your throttle is cable controlled by you pushing on the pedal. That being said. your launch control is usually (99%) of the time controlled by the clutch switch. you need to verify the wiring to that switch to get rid of that problem. I am willing to bet that the ground for that switch is a part of the same circuit that is causing your gauges to not work.
Rip It Up
Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
i vouch for my Brothas
Originally posted by JaK FRoSTWhiTE View PostMoney bet you fried your under dash multiplex.
Originally posted by Extacee View Postx2 when i tucked the wires on the passenger side i forgot to connect the main ground that is usually bolted to the side of the fender. i got a slight problem with the light s not working right until i connected it. it should be a ground somewhere.
Originally posted by zack_odom View PostNo. It isnt funny. Happened to me to.
check the Radio fuse under the hood. That same sort of issue happend to me when I worked on my car once. That fuse was blown. give it a shot.~Nick~
