Fuel Injectors upgrade more HP?
    well i just wondering that if say you replaced stock accord/civic injectors to 300cc or higher, would that give better performance with or without basic bolt on's?
    Sorry X, I'm piggy backing... On a related note, does anyone know if I can use the injectors from a 2002 Accord VTEC with my existing ECU? What about with a 94-95 Accord EX (P0A) ECU? And last thing, Anyone know what the stock flow rate is on these ('02) injectors?
    Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
      the injectors wont give you any type of horsepower they need to be matched with the same kinda of stock ones unless you really modded your car hard. If its stock your just really sending more fuel that doesnt know where to go and youll end up running slow. It has to have the right amount of fuel to mix in with the air.
      Kabuki as for the ecu thing your on your own on that one I dont know about that I just say get right ecu for that was made for thaat kinda of car so it will run right.
