Signal lights not working?
    Hey people I been all morning trying to fix my sigjnal lights they don't wanna work I bought a relay and put it in and still nothing all my bulbs are good my hazards don't work either and the hazards fuse is good any body have a idea of what could it be help pleaseeee.
    92 Accord Cb7 ^^
    My Ride Thread~~Click Below.
    http://www.cb7tuner.com/vbb/showthread.php?t=176232
    hi try a different hazards switch ..the turn signals are wired through it
      ok i really need help with this all my lights work when i hit my hazards button but when i got to put on my blinker left or right i get nothing and i tried almost everything new relay new switch in the steering colum umm all fuses checked all good does anybody have any other ideas pleaseee please help neeed help.
      92 Accord Cb7 ^^
        help!!!!!!!!!!
        92 Accord Cb7 ^^
          does the dashboard lights blink at all or is it completey dead?
          view my ride: My Ride
            yea everything works as normal but when i try the blinkers nothing works at all not even in the dash the green arrow but if i put my hazards the arrows blink and all my lights like they are supposed too
            92 Accord Cb7 ^^
              Did you replace the hazard switch?
              Your first post said the hazard switch doesn't work then the next says it does.
              Either there is a fuse blown, the combination switch is faulty, or the Hazard switch is faulty.
              Have you checked all of the fuses?
              Edit: Did they just stop working one day, or did you do some work and then they stopped?
              My 5.7 LS1 Holden Ute
                sounds like a faulty combo switch.
                  can it be the hazard button on the dash even tho my hazards do work? the relay is good.
                  92 Accord Cb7 ^^
                    your hazards work and flash all the signal lamps, right?
                    its unlikely that your hazard is at fault.
                    but start by swapping a new/working hazard switch. its cheaper and a million times easier to install than a combo switch.
                    if that doesnt work then you can focus on your combo switch, or elsewhere in the car....
                      New switch, check wiring?
                      life is good.
                        Last time I had blinker failure I had to change out the whole fuse block.
                          no its not the hazards switch or combo switch idk what else to think of.
                          92 Accord Cb7 ^^
                            Find an extra fuse block somebody might have. I looked all over the place for a short in my blinkers and when I got fed up a changed out the fuse block and BAM!
                              try checkin your interior light fuse
                              Team Accord #17 F & H series or no series....Rota Slips are the new steelies -_-
