does anyone knoe how to install this bad boy? or color code the wires? i bought it off a friend of a friend so hes doesnt have the intructions. Help me out if you can....or if you have installed one b4. Thanks for reading
I am no longer using this forum name.
You can find me as jdm_inspired... I'm starting all over again since I got another CB.
thanks...i happened to find the info after i wrote this. BUT...im concerned on where to put the green and white wire.....thanks for the help
ok, you can hook up the white wire onto any 12v ignition source.
i don't remember which wire on the dizzy to hook up to, but on the ecu, you can splice the green wire onto the "A" plug(largest plug on the ecu), pin A21. *here's a pic from the swap "FAQs" thread, courtesy of BustedLx:
for the green wire, if you don't want to tap the wires on the ecu, you can also tap the YELLOW/GREEN wire coming out of the distributor cap. there is only one set of wires coming out of the cap and one of the wires should be YELLOW/GREEN. that's the rpm signal wire similar to pin A21.
