ok well this has me, and a couple other mechanics stumped. to start off i have a F22B1 engine w/POA ecu and a H22 AUTO LSD tranny with 40k miles with a P19 tcu.
so my problem is that when i drive my car, most of the time i only ride in 1st and 3rd gear. when im on the high way it shifts to 4th. but in the city my transmission only shifts one time. the only time that my car shifts 3 times is when after i drive i turn off the car for about 10 minutes and turn her back on OR when im slowing down to a stop sign and then hit the gas again.
also my reverse gear takes about 15-30 seconds to kick in. started happening when the other problem started.
so far this is what i know and have done to try and find a remedy:
1.tranny is in good condition, problem occured with old tranny
2. TCU has no codes. opened up the tcu and everything looks good
3. did a drain n fill with Honda ATF.
4.CEL codes 41 and 21
when the car is having THE PROBLEM it feels very sluggish, i hit the gas and i slowly go fast. but when the car is acting normal, it feels super quick and responsive , when i hit the gas the tranny either downshifts or picks up speed super fast... kind of like if vtec is engaged.
these are what i think could possibly be the problem..
1. vtec isnt hooked up
2. shift cable is messed up
3. need a new tranny mount
4. need to switch the A6 and A11 pins in ecu (i doubt it though because these two wires are for the o2 sensor and EGR)
anyone has any ideas on where i should start looking for the problem or anything else i can check?
thanks in advance!
thanks in advance!
