Well i took apart my clutch to day and it looked a little fryed. Anyways is there any way to tell. I have a Daikin clutch is it any good. Should i just go out and buy a new one.
Is My Clutch Good
Park your car on a hill facing downwards and put the car in 1st gear.
Turn the engine off
slowly let go off the gas.
If the car begins to slide or studder, its probable that your clutch is worn.
If the car holds, have a friend push from behind while your foot is over the brake.
If he can push the car, chances are your clutch is worn
ya, who knows...what other problems are you experiencing?2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
no prob bro! Glad to know you're sittin pretty. I've heard from a couple of people that the clutch can look used just simply because it's been used alot...but it hasn't necessisarily been worn to the bone.
PTAC (Poor Tuner's Accord Club) - #05
2003-2006 - '91 Accord EX 2dr 5spd "Macy" R.I.P
2006-20?? - '99 Grand Am SE 4dr Auto "NoName"
i took my stock clutch to school yesterday for my instructor to look at.
the clutch plat looked fine (like a 13-14 yeard old plate would look) with hot spots of course, but my disc and flywheel where terrible.
the coil springs on the disc were chipped in areas, the disc was worn to the born, and hte flywheel, had hot/blue spots, showing where the disc was slipping bad.NEED RAP BEATS.....
www.soundclick.com/akcidentaltrakz
