My 91 ex has been down for a second like almost a year what precautions should i take when staring it for the first time. Since a weirdo decided it to jam my ignition i have ran into a problem hard to turn from off position with no battery connected should i connect the battery...and try again...or what i have a aftermarket (NAPA) ignition cylinder, wiring harness, and oem tumbler.. will post pics if needed...
91 Ex Been Down For A Second
http://cgi.ebay.com/ebaymotors/1991-...Q5fAccessories
buy this one i was thinking unless some one has a full one for sale...i have a exCB7 Neon
Originally posted by TRUEGREATNESSGD View PostMy 91 ex has been down for a second like almost a year what precautions should i take when staring it for the first time. Since a weirdo decided it to jam my ignition i have ran into a problem hard to turn from off position with no battery connected should i connect the battery...and try again...or what i have a aftermarket (NAPA) ignition cylinder, wiring harness, and oem tumbler.. will post pics if needed...
Just as a precaution its always a good idea to remove the spark plug leads and crank the car until the oil light goes out to ensure there is oil in the head/camshaft.
Then reconnect the leads and start it up.
Get a new ignition, or get it repaired.
My 5.7 LS1 Holden Ute
