my gauge cluster lights r out i need help!! =(
all my gauge cluster lights r out HELP!
Clock still work? Instrument cluster gauges and lights work? Little lights on A/C controls? When you turn on the headlights does the clock dim and the little lights on the A/C dim? Does the ashtray light come on? Glove box light? Dome light work?
I have an entire wiring diagram in front of me. Tell me what works and what doesn't.
Been playing with any sort of wiring lately? Kicked the underside of the dash inadvertently? Bad combination switch?
Details! Details!Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
Okay, even though you've said that you've checked the fuses, check them again.
There's two fuseboxes, as I'm sure you already knew, in the car. One is underneath the dash at the left kick panel, and the other's under the hood at the left rear corner of the engine compartment.
Double check them- every one of them.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
Originally posted by 91AccordLXalso check the Dimmer switch beside the steering wheel...you know the thing that makes the lights brighter on hte cluster...if that is unplugged the cluster lights wont come on at all...
1966 Chevy Nova
1974 Super Beetle
2012 Ford Super Cobra Jet
2004 Honda Element
2004 Honda Ruckus
2003 Honda Ruckus
www.weezoonline.com
www.facebook.com/weezoonline
automotive electrical problems=not fun
figured out why the lights werent turning on the white plastic cover on the back of the cluster had shorted out an electrical path on the circuit board i finally figured out where it was coming from after taking everysingle component in the cluster apart, tested it and saw the smoke coming from the short unfortuneately the circuit board was damaged beyond repair the heat had melted 2 of the paths together and i thought it would just be easier to get a whole new cluster...so off to ralphs...3 hours later new/used cluster works kept all the old guages and even the odometer transfered over nicely...all in all i would not want to ever have to go through this again it was costly and took forever to diagnose..i rolled around with no dash lights for at least 3 weeks!! if anyone experiences this problem heres a possible answer
