squeaky noise
    squeaky noise
    My 1992 Honda Accord EX recently started making a constant rubbery squeaking noise. It sounds like a cycling noise, maybe one of the belts? Anyone else have this problem? or have an idea of what it may be?
    Thanx
    altenator belt
      If your a/c pulley wobbles due to bad bearings it'll make the belt wear on the edges and make it make all sorts of goofy noises.
      Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
      1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
      2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
      2008 Ford Escape XLT [bone stock]
      2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
        alternator belt/power steering belt
        Went out and bought a alternator belt. Should I go ahead and install the new power steering belt as well?
          well you are going to have to take off the p/s belt in order to put on the alternator belt, just inspect it for cracks and splits.........if it doesn't have any you don't have to
            Make sure they're tight enough. If not you'll get screeching noises upon engine load or when the a/c kicks on.
              i got this too, one of the belts i dunno which one, its annoying but i doubt its worth changing out just to fix the squeek. maybe try some belt dressing ..
                done and done
                changed the p/s belt and alternator belt, no more noise. Thanx for the advice fellas.
