Ok. So I need a clutch for my '93 'Lude. I have the same F22a1/6 in my Accord as my 'Lude. I went to Autozone to get a clutch price, and I get quoted at $200 for a Prelude clutch. I price an Accord clutch and it's $99. Now I know the trannys are interchangable, but the guy behind the counter said that the spline or spindle or something is 1/32 in. off and 1/4 in. smaller diameter. So I went on Ebay to look one up and everything I find on there says ALL MODEL ACCORD/PRELUDE.......So wtf is going on? Can you interchange clutches or not? And if I get the clutch kit for the Accord, will I still be able to use the pressure plate and throw out bearing? THANKS for the help!!
What Clutch FITS?!?!?!
if your going to spend $200 on everything, this is the way to go:
I sware by LSD clutches. Click here then on "Drivetrain"
Just got this one for my red H22
Originally posted by wed3k View Postan f22 will fit but i wouldnt trust it to support a h23's power. my pressure plate started slipping after 30k with hard use on a stock f22. (exedy oem but works great for dd, im on my 2nd one)
member ride thread
DIVULGE MOTORSPORTS
What I don't understand is that both cars have the same motor and I'm guessing they have the same tranny, I haven't checked. So in theory, the clutches should be the same as well. What I'm thinking of doing is just getting the Autozone clutch for an Accord and if it won't work on the 'Lude, just keep it for when the clutch needs replaced on the Accord. Sound good or is that just retarded?
Originally posted by midnight_1 View PostWhat I don't understand is that both cars have the same motor and I'm guessing they have the same tranny, I haven't checked. So in theory, the clutches should be the same as well. What I'm thinking of doing is just getting the Autozone clutch for an Accord and if it won't work on the 'Lude, just keep it for when the clutch needs replaced on the Accord. Sound good or is that just retarded?**Blk Housed Slut Crew Member #1**
So this is what I found out. I checked at Autozone and the specs for the clutches are thus:
Accord : 8 7/8 diameter clutch disc, 1" (center hole, I forget what it's called)
Prelude : 8 5/8 diameter clutch disc, 1 1/32 center hole thing
And I've seen some online that have the center hole at 1 1/16 for Accords. So this may not work b/c it's smaller than others that I've seen. I'll keep you guys updated if it works. I bought the Accord clutch for the Prelude today. Now I just gotta put it in.
all clutches are interchangable between the h and f series engines.
member ride thread
DIVULGE MOTORSPORTS
