Why does my Accord vibrate?
    i have a 92 ex automatic. when i come to a stop or idling in park, the car vibrates pretty bad. there are a lot of rattles inside the car. when i give it just a little gas the vibration goes away. could it be my engine mounts? i've visually inspected them and they look okay, but i guess you really can't tell until you take them off.
    I think its more of a motor mount but if you hear clanking as well could be that too
      wow, thanks for the fast replies. i think i am just going to replace the mounts because i'm sure they have never been replaced. it seems 3 of the mounts run about fifty bucks each, but one is like two hundred bucks. this happened when i replaced my mounts in a prelude i used to have. the guy at the dealer said that the expensive mount hardly ever goes bad, so i only replaced the three, and it was fine. is this the same for the accord? thanks again.
        try to do it yourself if you can and check to see if which one is cracked to determine that.
          yeah, i had my front motor mount replaced due to vibration and it went away for a year. Now my car vibrates like crazy when i put it into reverse - especially with the AC on.
          BBB= Black Bumpered Beauty
          MY MEMBERS RIDE PAGE
          '98 Prelude (BB6) Type SH
            my fuckin car vibrates like a bitch in reverse, mostly cuz its my rad vibrating, and in park a lil too, but in neutral the bitch is sleeping thats y i hate automatic....dumb transmission
              if it reverses in reverse its that front motor mount...go inspect the inside of it....
              how low is ur idle...i suspect motor mounts as well..dont let it ride out too long on bad mounts...first its the front mount, then the rear...the rear costs a grip...then its ur tranny.
              to inspect the front one, look inside not at the flap of rubber...then see if the rubber is on the metal wals...if not then well its gone hehe..
              Retro!
              Hater
                Will it really damage your tranny? I've been riding on a broken rear mount for sometime now, I wasnt aware that It'd cause serious probs.
                mmmmmmmmmmmmmm....... DOHC
                  im not sure for sure...but i heard that it does affect ur tranny..when my rear mount broke, i replaced it right away.
                  Retro!
                  Hater
                    I have to remove my front motor mount due to my turbo, now the car vibrate alot in reverse, but if I gas it then the vibrating stop, my idle is around 700RPM. from what I can see the 3 remaining mount seem ok, the engine don't move much when I go from park to drive and neutral. what can I do since I cannot install a new front moter mount??
                    90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
                    < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
                      I am experiencing the same problems.. Reverse and park vibration... I was told that a rear hydraulic mount might fix the problem what do you think?
                        Black and Tan, I just e-mailed you the e-bay auction that I bought my rear mount from. $ 59.00 and it works fine. If the the auction has eneded call them and they will probally honor the price. The cheapest I could find it elsewhere was $150.00.
                        Ed
                        93 Accord Lx Coupe Auto
                        191,000 miles and still rocking
                        "There's nothing sweeter than my beater"
                          my moms m/t 91 ex only vibrates in neutral when the a/c or rear defroster is on ... these cars are weird what can i say.
                            maybe u just have a low idle...but check ur front motor mount....whats ur idle at
                            Retro!
                            Hater
                              i dunno about any of that shit but i aint checkin nothin i got enough trouble fixin all the shit from the accident! I aint bout to fix all that other shit ... hopefully my dad dont try to make a connection from the mount (if that it) and the accident.
