Knock Sensor
    Knock Sensor
    where is the knock sensor on the h22?
    My Honda
    im pretty sure it is above the oil filter. not to be confused with the oil pressure sensor.
    I <3 G60.
      yeah, my swap keeps throwing a 23 so i wanna check the sensor and wiring...i hope it's some wiring issue, i hear it's really sensitive, so im hoping that is all it is.
      My Honda
        Correct.
        Op - What is code 23? I don't have a prelude manual on me right now to see the flowchart.
        My 5.7 LS1 Holden Ute
          Originally posted by evil_demon_01 View Post
          Correct.
          it's the cel for Knock sensor, and if it's not 23 then the cel i get is for knock sensor, whatever number it may be, i just forget, i haven't pulled the actuall code in a while
          My Honda
            I know its the knock sensor code, but do you know the actual code reference.
            I.e knock sensor high voltage, knock sensor fault etc
              No, i don't know but if someone does, that would be pretty cool.
              My Honda
                most likely a high or low voltage. its a pulse generator i believe so it might have failed low.
                I <3 G60.
