I bought a 1991 Accord none running and no real info from the seller of what happened or what they did to the car. Car has spark and fuel but wouldn't start. Replaced the ECU with one from a 1992 Accord and got the car to start but only idles between 500- 600 rpms and with any throttle car bogs down and will die. See below for video Swap the ecu from a 1990 accord and does the same thing. I tried to pull engine codes, found none.
What I have done, with no change to the car
check compression reads 150 150 148 150
check spark plugs, found them gaped correctly but black and a heavy smell of fuel
fast idle valve was loose so I tighten it
map sensor replaced
fuel pressure reg replaced
replaced complete distributor thinking it had weak spark
cleaned the iacv
replaced spark plug wires
replaced injectors thinking one or two were stuck open dumping raw fuel
replaced Throttle body along with tbs
I am now lost and don't know what to do next!!
map sensor replaced
cleaned the iacv
