just yesterday my battery light turned on then everything started to die my lights,gauges, everything started to feel slugish then my CEL turns on.I take the battery to get tested n it was no good i get a dura last gold i hook everything up now everything works fine but my battery light still stays on
battery light stays on
Originally posted by nine_deuce View PostA quick way to check your alternator is to start your car, unhook the negative battery cable. Your car should continue to run. If it dies soon, your alternator may be bad-Will
Check the output of the alternator with a multimeter. With the engine idling, the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing, but my voltage meter on my radar detector normally reads 13. I think it reads low, but if it's accurate, I haven't had a problem with the alternator yet.
life is good.
Originally posted by DJ metadelic View PostCheck the output of the alternator with a multimeter. With the engine idling, the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing, but my voltage meter on my radar detector normally reads 13. I think it reads low, but if it's accurate, I haven't had a problem with the alternator yet.
Samething happened to me on my way home from the AFM09 meet. I had my wife and sister in the car with me. I was literally only an hour away from home!!!!! I already drove 19+ hours from florida. I live in NY and my alternator took a dump on me in NJ. In the middle of the night. My battery light came on as soon as I got over the delaware bridge and every light dimmed. I knew it was my altenator. I called a cab and had my wife and sister catch a train. I didn't get home till a 16 hours later.
Sorry to thread jack. Just wanted to share my experience with the pesky but helpful battery light.I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Originally posted by Racer_XXXExcuse me miss, YOUR FUPA IS IN THE WAY!!!
alternator. pull one from a CD accord and swap the pullies. i think there is a +10 amp rating. im not sure whats the best oem alt upgrade but i know the cd one fits
if your alternator is only a few months old tho then i would check your battery terminals and grounds. if your still riding on oem terminals invest in some tsunami terminals at autozone. they are 15$ each but i have them on all my cars and everyone's car who has had a problem in the past and no issues.
