Hi there, I am having trouble with this Code Alarm's 2 ways pager alarm w/Autostart. The Autostart function just won't work when the temperature is cold, below 0'C. I had replaced the alarm unit already, and same thing happened, so I don't think it is a bad unit. I can do Autostart when the weather is warm, so I don't think it is the wiring. On the other side, I can start the car with the key no problem in any weather condition, so it is not the car itself.
What I see/hear when I activate the Autostart is that the light on the dash go on, the fuel pump start running, and then I hear a "click" sound under the hood somewhere, and that is it.
If the problem is not the alarm unit, not the wiring, not the car it-self, what could it be?
![Confused](http://www.cb7tuner.com/confused.gif)
