Clutch engageing/disengaging
    This only happens in 1st and reverse
    sometimes it wont go into gear with clutch all the way in...
    but once i release full pressure it slide in fine...
    some things i was thinking is flushing the gear oil
    next check under the dash to see if its anything else
    then check the arm and see if any clips are missing
    is this bad or anyone got any ideas?
    .My Ride.
    It's perfectly normal. Sometimes the gears come to a stop in an unmatched position (i.e. tooth to tooth instead of tooth to recess) The owner's manual recommends that you try putting it in neutral, letting the clutch out and pushing it back in, then trying to put it into gear, or you can do as you have been and slip the clutch a tiny bit to nudge the gears together.
      You can also just try to put it in any other gear. 1st is on the same shaft as 3rd and 5th, so if you try to put it in 3rd or 5th you will probably work the shaft around some so it will slide in easy. Reverse is a straight cut gear, so it can just be difficult.
      tl;dr: Just try putting it in a different gear, it will work the shafts around.
      1992 Prelude S w/swapped H22A
        and changing the gear oil every few years isnt a bad idea either
        1990 accord Honda-Challenge, H22 powered
        newer race video,older race videos
        1991 accord parked, parts and back up shell
        1993 accord acquired 6-11-16
          1st and reverse don't have syncros, so the gears don't always line up perfectly first time
          My 5.7 LS1 Holden Ute
