car: 92 accord lx w/jdm h22a1 swap
the car takes forever to warm up so i came to the conclusion that the thermostat needs to be switched out.. but thats not the main problem. it seems that the car idles fine when cold.. but if i give it some gas, she sputters a bit between 1500-4k rpm.. but when the car is at normal operating temp, there is no sputter or hesitation at all.. can that have something to do with the thermostat or should i be looking somewhere else? i dont see any vac leaks, or anything out of the ordinary.. someone pls help me out.. thanks!
