o2 sensor removal
    o2 sensor removal
    i want to paint my heat shield but i cant remove it because i dont know how to get the o2 sensor out.do i need a special tool kuz i couldnt get a wrench in the hole to get it.
    92 Accord EX - SOLD
    PSN: REDxMAN-_-
    MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
    17in should doit, turn it counter clockwise and out she goes. But you don't need to remove the 02 sensor to remove the heat sheild.
      how do i take it of without taking the o2 sensor out?
      92 Accord EX - SOLD
      PSN: REDxMAN-_-
        Like the guy above me said you don't have to remove the o2 sensor to take off your heat shield. I actually did this today. 12mm socket will take out the three bolts. Then follow the wiring on the o2 sensor and you will see a plug that you can unplug about 6 inches or so from the sensor. Unplug that, unscrew the bolts, and then remove the shield.
          awsome, thanks now that and my valve cover are getting painted tonight
          92 Accord EX - SOLD
          PSN: REDxMAN-_-
            good luck on the job.
              Just take your time and make sure you prep it right. We'll need pics when your done too lol.
