ground wiring
    ground wiring
    ok, i was looking at hyper ground wires, and they say that they cause 5-10% increase in horsepower and all that good shit. does anyone know if these work? and would a good gauge amp power wire do the same as the hyper grounds? i cant afford the hyper grounds, and i wanted to see if the amp wires might work. im trying to get out of the 17's like you have no idea. im desperate. but i have no money and just lost my job, and im only 16. this sucks.
    --seth
    for sale
    sony 430 watt 3/2/1/ channel amp
    sparkomatic 60 watt eq
    i wouldnt say that u would see that much in horse power improvement.
    comparing it to a normal amp wire, some people do use it and its fine. but the wires in a amp wire are thin and the battery wires are thick copper carrying more voltage.
    i seen others use a huge metal thing thats really thick to ground. iono maybe someone has more input on this
    can u post a link?
    Retro!
    Hater
      good old 4 Gauge power wire about 15 feet ($25) and 12 connector for 6 wire set($4), a metal or alum plate with 6 hole drill ($4) and 6 stainless steel bolt and nut ($2) total about $35
      IF your engine is old and dirty, fresh new ground wire will gain back a few HP and even more for people with ignition upgrade and higher electrical load (amp, stereo, LCD...) Honda tunning magazine install hyperground on a new 2003 wrx and gain 2 HP/2TQ, but they say hyperground wire have shielding EMI foil and other material that normal power wire don't have. DOn't know if it true or not, but this cheap mod wil not hurt performance specially if you have amp and sub u will blown less fuses
      90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
      < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
        mostly just smooths out power production and improves idle, deffinately won't hurt. Just make your own kit though. Use shielded wire when possible, and gold connectors or at least plated.
        - Nathan
        Nathan Morris
        92 Accord LX - RIP
        92 Civic CX B18B1 Hatch - RIP (126whp, i/h motor)
        99 Civic EX Coupe w/ 1.9L stroker on the way, current at 121whp.
        nonVTEC.com - Technical discussion for F, D, and H series nonVTEC tuners
        H22Power.com
          my ground is rusty on my chassie....i think ill clean that up....
          Retro!
          Hater
            Cheap solution that I've done on all of my more performance minded cars. #4 Welders wire, it really (and all of the "Hyperground" type systems) won't make much of a difference in terms of horsepower, will help you idle better. I did my 3 major grounds on my Civic and noticed better fuel economy (and that is not a great concern, but even better MPG even though I am always on the throttle). These systems do work well in conjunction with an upgraded ignition.
            Here's a pic of what my wiring looks like, yes, the engine bay is very dirty, lol
            - Phase 1ne, get off of lazy arse and put in h23, then do some bodywork and paint
              very easy mod aint it?
              that wire u use, where can i find it..i got a ittie bittie little wire comming from my valve cover to the chassie and its ugly...is that the wire thats copper inside and thick inside? or was that pre-made?
              this is a nice DIY project, even if it may have little gains...its still worth it.
              i did my friends ground...his was gone...now his car is idling better.
              is that a ready made wire? or u assembled the terminal rings...
              i can do that to my battery terminals too right...positive to ground?? JK haha.....
              Retro!
              Hater
                http://www.importtuner.com/tech/0308it_pptalon/
                check that out...
                Retro!
                Hater
                  http://sunautomobile.com/hypergroundsystem/
                  hit that up
                  Retro!
                  Hater
                    i personally like celldotorg's setup...its clean and cheap
                    Retro!
                    Hater
                      what parts of the engine bay are grounded in out cb7's, i can only think of one off the top of my head....i wanna go and do this now, and heres a dumb question i no the answer to but im dumb anyway do all the grounds connect to the ground on the battery...
                        i have 3 different locations. mine are going from the battery to the block, from the block to the chassis. battery to chassis, and finally block to motor mount to chassis. seemed to work out great for me. improved my idle and gave me a liitle bottom end power. i am still going to put one more in and it is going to go from the firewall to the intake manifold back to the firewall.
                        www.rms-usa.com
                          so what should i ground on my accord im just asking so i dont have to look in there and see for myself cuz im too lazy and stuff...
                            the way im going to do it, is just reground the grounds comming from the valve cover, the power steering, and the motor mount.
                            thats it for now. in the future i will re-ground the negitive terminal with a whole new terminal.
                            hehe im into little things...not no biggie stuff u kno...i bet u guys will go more out than me....but i dont really really need it
                            Retro!
                            Hater
                              The beauty of mine is that I paid $16.50 total for the materials and then did the labor in about 45 minutes (I am very anal on good connections so some sandpaper was used on all connection points) all and all, the Cheapest DIY I've ever done.
