My friends 92 accord will not start. He said it was running fine the other day. he stated the lights on the dash board do not come on and no clicks. he comfirmed the battery is good and fuel pump does come on. fuel pump does come on when he tries to crank it also but no clicks or any thing. me and him are puzzled. i was guessing ignition switch but i dont know.
No start
Originally posted by visualpoet View PostThe fuel pump comes on, but the car doesn't crank? Battery could be extremely low, or the starter could be bad, or there could be a blown fuse. Check fuses first, then start tracking from there. Do either of you have a volt meter? It's going to come in handy if the fuses are all good.Need CB7/H22/Turbo parts? i got them..check thread
do a volt test if you have a meter..if you dont ,they are not expensive basically you can test to see if the battery has a charge..and if there is a charge going to your starter..cant be to hard to figure out it may only be a few thing..what about a loose connectionhttp://www.cb7tuner.com/vbb/showthread.php?t=167601 Click to see my new ride
