Info Needed!!!
    Info Needed!!!
    Anybody care to fill in the wire colors and connector colors for the coolant temp sensors as follows:
    Water Neck Sensor:
    Sensor under the dizzy:
    Sensor on Thermostat housing:
    Im still tryin to figure out the reason why im getting a code 10, I have ran new wires, ran every diagnostic known to man and swapped out new parts and everything, tha only thing I can think of is that I have the sensor harness connectors swapped up are something
    bump
      lol, we'll see if the ecu is sending a voltage signal.
        How do I go about doing that? I swapped the ecu for a known working one
          bump
            and which wire would that be?
              with the key on but engine off, probe each wire till you find a 5 volt reference. that will determine your source wire. if you see no 5 volt source, maybe your ecu isnt sending power.
