cars not runnin right somewhat?
    OKay I have problems with my car a bit slow I feel it in my ass dyno sure I know go ahead and laugh but you know and feel your car especially if somethings wrong with it. Okay with the fuelpump with a aftermarket fpr will that be fuel overkill for my car if i have it set at 41psi ? will it make it slower? I have cai,custom exhaust no cat, and a stock header. or is it the way i drive or is it the fact that im getting too used to the car?
    you could do that or turn the pressure down slightly...or if you really want to take advantage of it, get an upgraded ignition to burn off all that excess fuel you're dumpin
    "Once a CB7 Tuner, Always a CB7 Tuner"
    Former h23 swapped accord owner...
    2002 Acura 3.2CL
    20" Rims and Brembo Brake Kit - Ridin classy and slow
    1994 MKIV TT Supra
    BPU+++ (under the knife, getting nastier)
      I did put the stock one back on check engine light keeps coming up and plus I have 255 fuel pump in there as well by venom
        Its throwin the o2 code thats about it but the shit came off my accord though and I used the other one same thing.
