Exhaust stud removal?
    Its time for 'um to be replaced! They're old, rusty and need to Go! So how do you replace them?
    Is there an exhaust leak or something? Or do you just want a cleaner look?
      u need 2 nuts. put one nut on then chase it then remove the one u put on 1st with a wrench.
      [COLOR="Magenta"]
        Well cuz they are so old I dont want them to break when i torque down my new manifold
        Duh! Why didnt I think of that!!
        Thanks
          does APR make studs that i can use?
          can someone help point me in the right direction? please
            But, if you do not care about the studs you are removing, something like this will be much faster and easier.
              And what is that my friend?
                that would be a stud remover
                you use a 3/8s ratchet, and place the stud through either of the holes on the tool, and turn it. the toothed wheel, cams onto the stud, kind of "grabbing" it, in which it will turn and loosen the said stud.
                  Remove exhaust manifold and double-nut the studs, then remove. Consider ARP exhaust manifold fasteners, TAS also sells them to replace them. If I had reason to replace them, that is what I would do. Makes for easier header installs later too.
                    Awesome!
                    Thanks for the help guys!
                      Originally posted by nate'sCB7 View Post
                      Awesome!
                      also when ur done putting them back in spray them with primer so they dont rust again...better yet use the high heat paint.
                      my new turbo build
                        Anti-seizing the studs will prevent rust too.
                          Yeah, i went to autozone and got a package for $1.99
                            as old as the studs are, they rarely snap off.
                              So i just foud out i have two snapped studs!! How should i get them out???
                              90 Panda DX F22A6
