need help!!! obd2a 96 prelude eith obd1 engine
    ok guys i need help with somethin. i have a friends car 96 prelude h23 that blew a motor. we put an engine with a f22a6 block/h23 head, we are using the cars oringinal harness and have swapped over the original injectors and all other components from the head needed to run this engine. the car is obd2A however due to the lack of provisions for the two crank mounted sensors on the f22a6 block we have no choice but to use an obd1 dizzy and obd2a-obd1 conversion harness to run the obd1 p14 ecu. however we can not find a wiring diagram for the engine on an obd2a engine. i need to know how to correctly delete the crank mounted sensors and re pin them into the obd1 dizzy connector so we get all the signals right. we should be able to instll an obd1 distributor on this car and just rewire the 8 pin connector with the four wires from the two crank mounted sensors. seeing as how the obd1 dizzy's have all the needed sensors inside it. they just need to be wired up. if you have the obd2a wiring diagram or any real info on how i can mke this car run correctly i will gladly pay ou via paypal for this info if it works. please help!!!!!!!!!!!!!!!!! please reply to this post or email me personally at nickolascolvin@yahoo.com or call me at 469-247-5873 my name is nick.
    My other ride is your ex-wife
    if you still need an ECU, I've got a 96' OBD2 P12 out of the Prelude S...I've been trying to get rid of it forever, but everyone on the forum is OBD1 and it'll run your F22A6 much better than a P14 would I'm thinking, since that ECU is for a DOHC motor.
      hi i saw a 97 lude info here http://www.spoonertuner.com/manuals?...9&Redirected=Y it might help
        I've got access to Alldata if you want I'll check at school tomorrow. PM me Year make and model for the motor and I'll see what I can find.
