jumpy speedo sometimes? Possible speed sensor?
    I've noticed recently that my speedometer "jumps" or kinda flicks when I'm accelerating hard. I've got a JDM H22 M2A4 5 spd trans. Is it just the speed sensor going bad on me?
    The thing is, I'm using one from a used H23 in my H22 trans. I don't have the PS lines hooked to it though. But when I first put it in there a couple months ago, it never showed any signs of this yet I don't have any CEL codes popping up.
    So is it just the top part that I need to replace?
    member's ride thread
    91 Accord SE 176k
    Yea, its the very top piece that needs replacing it sounds like.
    I'd run the P/S lines into the speed sensor though
    Your local dealer has them, and they arent expensive.
    Plus the steering wheel will have variable input sensativity.
    If that doesnt solve it, it might be loose connections or screws for the speedo.
    Your man for wiring solutions!
    CB7Man's Coupe H22 Swap
    CB7Man's Sedan Resurrected From The Dead
      ok, the thing is....I still have the VSS from my MPOA Automatic trans since I did a 5spd swap. But that one looks different than the one thats on the car currently.
      The auto one seems to just have a plug/connector on it but the one in my car has a connector w/ a wire coming out of the top part. Still think it'll work the same?
      91 Accord SE 176k
        Ah yes I remember those...
        You can try it, but I cant remember.
        Yea the older automatic has a wire and a plug comeing out but the new manual has the plug molded into the VSS.
        I think the tops are the same, you may have to transplant.
        I have an H23 VSS in my T2T4 and no problems yet lol
