my rear defrost doesn't clear the rear window.
So far, I can confirm that the relay picks up (I hear it click when I push the defrost button - and the light on the button lights)
When I check with a voltmeter on either side of the window where the defrost supply wires terminate on the defrost grid, I activate the defroster I see 12.5v (key on, engine off) to 14v (engine running/charging).
I'm not sure if I have a grid-break or if I have a relay problem and am jut reading the relay pick-up voltage and not the actual output voltage. What should the grid resistance be from terminal to terminal?
