so i just got done wiht all the little things that were wrong with my car and i took it out for a real test drive and found out that my 5th gear is trashed. it goes in to gear but if i give it any gas it pops out and wount stay in gear i dont know what to do....any ideas
m/t trans problems
the transmission is not damaged beyond repair.
to repair it you will need more than just a bearing kit though. your 5th hub/slider is worn or the bearings are alowing sagging and or movement in the shaft.
if you do it yourself or take it to a shop it will be more expensive than a basic "Rebuild" as will require hardparts( hub /slider, possibly shaft).
knowing this maybe a complete used unit might be a better idea. then you can choose what one to install, h22a,h23 or f22 trans. all depends on your goals and budget.96 Accord SiR driveline installed. CF2 donar
I got a rebuilt one for 600 installed.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View PostI got a rebuilt one for 600 installed.
I have all the websites bookmarked as well.
