I've noticed my H22 burns oil, big epiphany there. But is 1-1.5 qts between oil changes in the acceptable range for these engines? I use VTEC quite a lot, prob. on every on-ramp, lets just say I use this engine for what I intended this swap for haha. But am I burning too much? or is that about normal? How much do your guys' H22s burn per oil change?
How much oil does your H22 burn between oil changes?
member's ride thread
91 Accord SE 176k
97' Honda Odyssey 199k miles...$485 spare van for my parentsTags: None
Originally posted by Losiracer2 View PostI've noticed my H22 burns oil, big epiphany there. But is 1-1.5 qts between oil changes in the acceptable range for these engines? I use VTEC quite a lot, prob. on every on-ramp, lets just say I use this engine for what I intended this swap for haha. But am I burning too much? or is that about normal? How much do your guys' H22s burn per oil change?
Originally posted by eriemoto. View Posti don't know specifically about the h22, but in general, for high mileage vehicles, burning 1 quart between oil changes is usually okay, given you change it at every 3-5K miles
I burned about this quantity on my mild NA F22ax project (red Accord) every 5-7K miles when I revved the motor frequently. I used Mobil1 5W30. The head was reconditioned on it, but block started with 200K miles on it, in great shape for mileage. I'm sure it would burn less with refreshed block, but not my intention to rebuild it for a quick DD mild NA project.
Note: My oil did not turn dark though. It retained good color, but oil level just went down.Last edited by HondaFan81; 11-09-2009, 11:37 AM.
Yeah I usually do 3k intervals
91 Accord SE 176k
yeah i guess an extra 8 bucks a quart every 3k miles won't kill me, ok cool, thanks for your 2 cents
91 Accord SE 176k
