car turns off cel comes on.
    i just change my lower tubes seals about 4-5 weeks ago, changed the spark plugs and wires, then about 2 weeks ago my car starts turning off randomly and the cell light would come on, its just a solid cel, then i would have oil in my spark plugs again this time on all 4, so i checked everything and found out that the rear acorn nut valve cover wasnt tight enough, so i tightened it and replace the spark plugs and wires again, theres no more oil down the tube, and it ran fine for a 2 days, but then today, it just turned off again and the cel light came back on, so when i got home i checked for codes and there was nothing. what could it be? bad dizzy? cap and rotor? or ecu?? i dont really know what could be causing this.
    MEMBERS RIDE.
    Bought from: DannyD , Night Wolf , CB7=91, lummieCB7
    Sold to: LITuner, rezist09, Pacman91EX, 93AccordLXwhite, PhatAccord, TheNextEpisode
    Is there oil inside the spark plug wires where they connect to the spark plug?
    Its wise to pull a CEL right away even if its not flashing.
      nope its dry. i always check before i start up the car.
      and even thou theres no cel i still check and still nothing comes up. when do the CEL comes up it would be solid.
      MEMBERS RIDE.
        TIP: A CEL doesn't mean it always has codes when lit. Sometimes the CEL lit without codes meaning there is something wrong with the engine. However , there is no specific code to accurately pin-point the problem.
        How's your main relay?
        How's your fuel pump?
        How's your ignition coil?
        How's your igniter?
        How's your fuses?
        How's your grounds?
        How's your battery cables?
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          might be a bad ignition switch cutting off the engine.
            How's your main relay? good
            How's your fuel pump? good
            How's your ignition coil? idk
            How's your igniter? idk
            How's your fuses? good
            How's your grounds?good
            How's your battery cables? good
            is there anyway to check if my ignition switch or igniter/coil is good??
            MEMBERS RIDE.
              id check that. does the car shut off liek something turned the key off?
                yea actually it does.
                its the exact same as this guy's problem
                http://www.cb7tuner.com/vbb/showthread.php?t=143749
                MEMBERS RIDE.
                  ttt
                  MEMBERS RIDE.
                    changing the distributor tomorrow since it has life time warranty at autozone hope this helps.
                    MEMBERS RIDE.
                      autozone is the shit for lifetime replacement parts
                      Be Clean
                        lmao i know, even thou some of theyre parts are POS but, hey its still lifetime warranty.
                        MEMBERS RIDE.
                          ok i just replaced the distributor today, so we'll see if it'll happen again.
                          MEMBERS RIDE.
