Intake Tube
    Intake Tube
    Where can I order just the cold air intake tube? I already have a K/N Filter and a tube, but I got the tube from a eclipse and modded it and the Starter boost tube thing and the pipe coming from the Valve cover doesnt work on it
    Search on ebay and you'll come up with tons of them. It won't be just the tub but it'll be cheap enough that it won't matter.
      I just paid 50 bucks for a K/N Filter, and all the ones on ebay are like 40 bucks or 50, and Im not about to spend 50 bucks just for the damn tube
        Lol. That's the only thing I know to do. That's what most everyone else here has done so I really don't know of a cheaper option other making one yourself or having a muffler shop bend a pipe for you.
          I mean I have the tube and filter now, but the hose coming from starter boost thing and the one coming from the valve cover isnt going to anything, can I leave it like this?
            The one comming from the valve cover i've seen people put a tiny filter on. The other one I have no clue about. You may able to just plug it but like I said i'm really not sure.
              Yeah I just have a breather filter on mine and capped off the spot on the intake.
              Idk what the other one you're talking about is though.
              Member's Ride Thread
              Originally posted by mercyboy
              I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
                The other one he's talking about I believe is the tiny one on top right by the throttle body. You can see it in your pic.
                  Vacuum hose from air starting valves does need to be connected to intake piping OR be capped off. Do not leave it exposed to atmosphere.
                  Purpose of that component is to provide extra filtered air when cranking engine over. Once engine starts & runs, it creates vacuum and it will close the air starting valve (if it works properly).
                  Block off air starting valve or cap it off if using performance camshaft, as it can cause vacuum leak.
