Ok guys, I'm swapping mine out and there's just not enough room (even with the IM out) to maneuver it around the mounting bracket. What's the secret? Nothing helpful here or on HT as of yet.
The bracket (#10 here: http://www.hondaautomotiveparts.com/...5=ENGINE+MOUNT) doesn't appear to be easily removed or loosened up. There is 1 bolt (headless) that has a nut on the bottom side, but I'm more than willing to bet that it's spot welded onto the underside of the bracket.
So, how do I get it off? Even with the heater core hose out of the way, the firewall is too close to move it. I've tried pivoting it as much as I could, no luck yet.
