I was wonder what brake booster is bigger and will fit an 9091 ex w/o abs
Bigger Brake Booster swap
IIRC the Prelude VTEC has a 1 inch MC and the EX/SE accords are 15/16ths. That'll prob. help a bit in clamping force.
Originally posted by mj213 View Post
So if you don't have info don't post please thank you
i could always bolt + jb weld it
and u gotta admit the buttplug was quite funny
oh also a side note. all 4g preludes WITH ABS have a 1" brake master cyl.
you can further research on preludepower.comLast edited by xkjnboix; 10-22-2009, 07:41 AM.
W/ either the VTEC m/c or the EX/SE m/c, you wouldn't be plugging anything at all, those still have 2 outlets, only difference is the rear flare fitting is larger, M12 compared to M10, like the front flare fitting. What you need to do is pull off the line that goes to the rear fitting on the m/c and flare on the M12 ABS fitting, all the ABS Honda's use them @ the m/c. If you're not up for that, I could def. make one up for you, I've done this afew times now for my ABS removal and H22Wagon93 and I sold an ABS removal package not too long ago w/ this modded line. If you have the fitting and you can flare, you can do this very easily Please LMK if you need me to clarify anything.
Oh, also, now is a great time to swap to a 4040 prop. valve if you haven't already!Last edited by Granite CB7; 10-22-2009, 05:58 PM.
